XML, ESI, queue had pending messages.
Version: Windchill 13.0
Use Case: We use ESI to transfer data to ERP, flat xml transfer of the changed data.
Description:
Problem is in analyzing and restarting the ESI/ERP Queues.
Where can i find the right queue and how do i restart this, or re-offer/restart processing the xml's.
(and why might they be stuck in pending mode, in the q).
This doesn't seem to be in utility's > queues management but a different gui/control in Winchill?
Any documentation or advice would be great, thanks.
Fadel
23-Emerald II
October 14, 2025
OOTB  Release To Manufacturing Workflow Instances are  are done executed in WfPropagationQueue .
Buiꓘa
Hello Fadel,
I'm still new to Windchill, this however doesn't look like the right queue for the traffic, maybe i'm described it wrong.
when User edits in Windchill the flow should be:
Windchill > export xml > bus/middelware layer> ERP/Oracle
the export xml and the transfer queue i need to find.
With kind regards, John
Community Moderator
October 17, 2025
Hello @JH_13978772,
It looks like you have a response from a PTC Expert. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
