Dec 9, 2014 11:50 AM UTC
XML template for exporting WNC data to Team Center or Enovia?
Anybody have an xml template to export the data to Enovia or Team center? I am working in a project and I wish to get some sample template instead of trying out many options. It would be great if any of you can share me the template you used for any PLM. My requirement now is for the Team Center .
Dec 9, 2014 2:57 PM UTC
Typo – your subject says ‘date’, not ’data’. Basic query webject could just dump everything except actual content files. Best to look at Windchill Bulk Migrator.
Selva1-VisitorAuthor
Dec 9, 2014 4:20 PM UTC
thanks for your reply. I will do check it out
Dec 9, 2014 4:42 PM UTC
You can write several custom programs using Windchill API’s to extract data from Windchill (Mata data and physical data).Windchill Bulk migrator would be good option if you migrating from one Windchill to another Windchill. Since you are migrating to another PLM. So I would suggest to write to custom java utility extract data from Windchill using APIs and also you can normalize data in same utility.
