客户本地选副本站点上传文件失败,但是服务器上可以正常上传
  • August 4, 2025
  • 314 views
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS22
客户端本机选择-副本站点,上传文件没有反应,F12报错:has been blocked by CORS policy: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource.
但是在副本的服务器上或者主站点的应用服务器上是可以上传的。
    Best answer by BL_9537051
    在codebase/WEB-INF/web.xml中加了 <filter>
    <filter-name>ContentCorsFilter</filter-name>
    <filter-class>org.apache.catalina.filters.CorsFilter</filter-class>
    <init-param>
    <param-name>cors.allowed.origins</param-name>
    <param-value>http://plm.xxx.com:80,https://plmfileserver.xxx.com:443</param-value>
    </init-param>
    <init-param>
    <param-name>cors.support.credentials</param-name>
    <param-value>true</param-value>
    </init-param>
    <init-param>
    <param-name>cors.allowed.methods</param-name>
    <param-value>GET,POST,OPTIONS</param-value>
    </init-param>
    <init-param>
    <param-name>cors.allowed.headers</param-name>
    <param-value>Content-Type,X-Requested-With</param-value>
    </init-param>
    </filter>
    <filter>
    <filter-name>ContentHttpHeaderSecurityFilter</filter-name>
    <filter-class>org.apache.catalina.filters.HttpHeaderSecurityFilter</filter-class>
    <init-param>
    <param-name>antiClickJackingOption</param-name>
    <param-value>ALLOW-FROM</param-value>
    </init-param>
    <init-param>
    <param-name>antiClickJackingUri</param-name>
    </init-param>
    </filter>
    <filter-mapping>
    <url-pattern>/servlet/WindchillAuthGW/wt.content.ContentHttp/viewContent/*</url-pattern>
    <url-pattern>/servlet/WindchillGW/wt.fv.master.StandardMasterService/doDirectDownload/*</url-pattern>
    <url-pattern>/servlet/WindchillGW/wt.fv.replica.StandardReplicaService/doDownload/*</url-pattern>
    <url-pattern>/servlet/WindchillGW/wt.fv.replica.StandardReplicaService/doIndirectDownload/*</url-pattern>
    <url-pattern>/servlet/WindchillGW/wt.fv.uploadtocache.DoUploadToCache_Server/doUploadToChache_Master</url-pattern>
    <url-pattern>/servlet/WindchillGW/wt.fv.uploadtocache.DoUploadToCache_Server/doUploadToChache_Replica</url-pattern>
    </filter-mapping>
    <filter-mapping>
    </filter-mapping>
    后重启了还是不行
    F12报错
    BL_953705112-AmethystAuthorAnswer
    <init-param>
    </init-param>
    <init-param>
    </init-param>
    <init-param>
    </init-param>
    <init-param>
    </init-param>
    </filter>
    <filter>
    <init-param>
    </init-param>
    <init-param>
    </init-param>
    </filter>
    <filter-mapping>
    </filter-mapping>
    <filter-mapping>
    </filter-mapping>
    后重启了还是不行
    F12报错
