Feb 11, 2026 5:56 AM UTC
权限无法导入问题
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS16
根据类型导入相关角色权限,使用命令:windchill wt.load.LoadFromFile -d /home/ptc/Windchill_11.0/Windchill/access/access.xml -u wcadmin -p wcadmin -CONT_PATH \"/wt.inf.container.OrgContainer=dns/wt.pdmlink.PDMLinkProduct=电子产品\" 无法成功导入权限,排查过相关xml文件内容,无法发现问题所在,特此提出技术支持。联系管理员:杜超帆;
18-Opal
Feb 11, 2026 6:20 AM UTC
Hi @WW_14456910,
Could you please share the Method Server logs generated during the load file import process
avillanueva
23-Emerald II
Feb 11, 2026 12:37 PM UTC
Please do not post personal numbers or emails. This board is not setup for personal, 1 on 1 tech support. @TDT suggestion is to post what the error is so the community can help. Please be sure to remove any sensitive information in logs and narrow focus to the import error.
