May 21, 2026 3:22 AM UTC
没有构建生成部件结构
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.0.2 1、普通用户检入CAD文档并选择自动将部件关联至CAD文档选项后,没有构建生成部件结构,· 2、普通用户在CAD文档的详细信息页面,操作》比较)与部件结构比较)构建多级部件结构时,出现以下错误:没有权限,这个权限如何给予 3、管理员在CAD文档的详细信息页面,操作》比较)与部件结构比较)构建多级部件结构时,出现以下错误:构建失败:无构建对象
18-Opal
May 21, 2026 12:29 PM UTC
Hi ​@SH_10397317 ,
Please check whether the following preference is set to Yes:
Build Part After Associate – This should be set to Yes so that the part structure is built automatically after CAD check in.
For the permission denied error and the build failed error, could you please check the Method Server logs? You can also share the logs.
May 22, 2026 2:39 AM UTC
没有作用,我们已经检入检出过多次也导出到本地然后重新检入,都无法成功
joe_morton
May 28, 2026 7:27 PM UTC
What happens when an admin checks in a CAD document? Does the WTPart get built?
If so, it might be a permissions issue. You’ll want to check the OIR that is controlling part creation, then make sure that regular users have permissions to create the WTPart at the initial life cycle state
