Mar 7, 2025 5:49 AM UTC
账号密码过期提醒
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS19
账号密码过期提醒,结合技术文章 CS211420进行设置后,过期邮件在第一次密码过期后会发送邮箱,但是再次修改密码后不再收到过期邮件
Emeritus
Mar 11, 2025 5:30 AM UTC
Hello @ZW_10422559,
Your post has not yet received any response. I am replying to raise awareness. Hopefully, another community member will be able to help.
Meanwhile, could you please provide more details on the following:
  1. Any specific configurations or settings you applied.
  2. Whether there are any error messages or logs that might indicate why the emails are not being sent after the password is changed again.
  3. If possible, could you also share a screenshot of your current configuration?
Adding a few more details to your post should help in receiving more meaningful response from peers.
Thank you!
Vivek N
Community Moderation Team
HelesicPetr
Mar 11, 2025 9:09 AM UTC
Hi @ZW_10422559
Can you provide a URL to the mentioned CS211420?
I can not find it
PetrH
