部件不同视图用户权限控制
I am using Windchill PDMLink Release 11.2 and Datecode with CPS 11.2.1.5
Windchill系统中部署了两大模块分为Service模块(A模块)和PackageBOM模块(B模块),其中A模块存在Service视图,A模块用户可通过右上角搜索,能根据编号搜索到Service视图数据,提示安全信息,B模块用户也能根据编号搜索到Service视图数据(安全信息),现在B模块搜索时不想看到Service视图数据(安全信息),A模块用户搜索时又想要Service视图数据(安全信息),Service视图数据存在多个产品库下,该如果解决?
    avillanueva
    23-Emerald II
    June 13, 2025
    Illustration or picture might help but each product/library can have its own users, roles and access rights. If the data is stored in separate contexts, you can prevent users of one from seeing data on the other. This applies to searching where you get nothing or if there is a link to an object that the user does not have access to, it will show only number/name and the rest is  "Secured Information" preventing further access. If this is what you want to have happen, then you just need to make sure the users are not in both areas. However, if you want to have a BOM or product structure share components, someone would need access to both to create the linkage.
    If you are referring to view version (I do not have the Service module installed), then I am not sure you can prevent access to views via ACLs. The ACLs do not go down to the view, just object level. I am not sure its possible to store different views in different folders, but if that was possible, you can configure different ACLS at the folder level to prevent access. Windchill would revert back to another view version like Design if it could not see a downstream view, depending on how you have your config spec setup.
    Community Moderator
    June 20, 2025
    Hello @博雅_11253669,
    It looks like you have a response from our community champion. If it helped you solve your question please mark the reply as the Accepted Solution.
    Vivek N.
    Community Moderation Team.
