Jan 30, 2026 4:03 AM UTC
零件檢視時,欄位顯示全域列舉的「內部名稱」而非「顯示名稱」
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.0
零件檢視時,欄位顯示全域列舉的「內部名稱」而非「顯示名稱」,但參考者零件檢視時欄位顯示卻又是正常的
18-Opal
Jan 30, 2026 5:08 AM UTC
Hi @JL_9763612,
Could you add some screenshots?
Feb 2, 2026 5:58 AM UTC
Component Only display internal code
Reference Parts is normal
Thank you for your help.
18-Opal
Feb 2, 2026 6:14 AM UTC
If possible, could you please share the screenshots with the language set to English?
I do not understand Chinese.
