Jul 15, 2025 7:04 AM UTC
신규 CAD에 대한 Check-In 시 Windchill Server로 Upload 불가.
I am using Windchill PDMLink Release 12.0 and Datecode with CPS 12.0.0.3
업로드 오류: 업로드 실패 code :J03_WCCLD_CONNECTION_FAILURE locMsg :연결 실패Applies To: Unknown Error / HTTP 연결 실패
특정 CAD에 대해서만 해당 오류 발생
Here are the errors that I faced
Catalina
Community Manager
Jul 15, 2025 9:18 AM UTC
Hi @YJ_9923893
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • Does the upload failure occur only with one specific CAD file, or with all new CAD files?
  • Have you verified if the CAD file path or name contains special characters or non-ASCII text?
  • Are you using a supported version of the CAD tool and integration with Windchill?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Here's what a good question for Creo looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina | PTC Community Manager
avillanueva
23-Emerald II
Jul 15, 2025 11:13 AM UTC
There are many articles that report back with "J03_WCCLD_CONNECTION_FAILURE" as the search query from the knowledge base.
https://www.ptc.com/en/support/article/CS443107?source=search
Did you start there and check for solutions first? That should always be your first step is the knowledge base. Reading some of these, it could be network related, a cluster issue, corrupt workspace, missing references. We need more information from you on this. First go through other articles and eliminate ones that do not apply. Reply back with more specifics on your issue.
