3-Newcomer
May 25, 2023
add suffix of an custom attribute to generate a number
Add EXTENSION attribute value (ex: EXTENSION - PART, set number like 123_PART.prt) as suffix to the number of the object using OIR.
extension is a custom attribute created under wtpart.
This article has the steps for your requirement
https://www.ptc.com/en/support/article/CS30442?source=search
Amar
HelesicPetr
Hi @amar_karthi
Do you know it the sufix is placed before.".prt" as @SS_10547676 needs or it is places in the end of the ".prt" so by the article it could looks like "123.prt_PART" ?
PetrH
