Adding a new state to a lifecycle
When we set up our production system at Windchill 8, we built a state.rbinfo text file in the wtCustom folder structure, then used an ant command to build it into Windchill.
I am building a new system and need to add a new lifecycle state, Searching PTC.com comes up with CS223984 (which is basically useless) and CS422321, using enumCustomize utility to directly modify the StateRB.RB.ser file directly and then run the ant MakeJar command.
Which method is best for adding enumerations to the system? I know the rbinfo file method still works.
Windchill 11.0 m030 CPS08
22-Sapphire I
August 23, 2019
Ben,
Always best to do this thru Enumcustomize - prevents errors.
- Windchill shell as admin
- >enumcustomize, GUI launches
- browse to rb file
- edit, save
- run command
- see result in /wtCustom
- delete /tomcat/instances and /tasks/…/ contents
- start WC
- test: See state available from Lifecycle Admin
Sorry, I miss understood the question wrong. Here the correct answer
open a shell:
enumcustomize
navigate to the lifecycle: wt->lifecycle->StateRB.RB.ser
Add the states to all the languages
ant -f codebase/MakeJar.xml custUpdate
Restart Windchill
22-Sapphire I
August 23, 2019
Ben,
- browse to rb file
- edit, save
- run command
- start WC
