Adding URL Variable to Change Activity JSP
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.2.8
How do I put an URL variable on a custom JSP page for a change activity? When I put the variable, it comes out as text.
    HelesicPetr
    Hi @BrianToussaint
    It is very simple. The url can not contain a space character
    you have to replace the space character with a encoding character %20
    check following link https://www.w3schools.com/tags/ref_urlencode.ASP
    PetrH
    avillanueva
    23-Emerald II
    I think you have assign a data utility to that variable for it to render as a hyperlink.
    HelesicPetr
    Hi @BrianToussaint
    I use a following code to build the a download URL for the URL link variable in the workflow that is set this object in the variable URL type that I show in the task page.
    //URL urlSet = ContentHelper.service.getDownloadURL(orderDocument, apData);
    String serverURL = AttachmentsDataUtilityHelper.getBaseURL();
    String urlString = serverURL + "/servlet/AttachmentsDownloadDirectionServlet?oid=OR:";
    urlString = urlString + contents.getPersistInfo().getObjectIdentifier().getStringValue();
    urlString = urlString + "&cioids=";
    urlString = urlString + apData.getPersistInfo().getObjectIdentifier().getStringValue();
    urlString = urlString + "&role=";
    urlString = urlString + apData.getRole();
    URL urlSet = null;
    try
    	urlSet = new URL(urlString);
    } catch (MalformedURLException e)
    	e.printStackTrace();
    the urlSet is the final object that is saved in a wokrflow variable and then I show this variable in the task activity page
    hope this can help
    PetrH
    @HelesicPetr, the  problem that I am running into is that I have a space and it stops the link at the space and then shows the rest but it isn't part of the link.
    String PowerBI_Lnk = PowerBI_WU_Begin + " " + wtpartList;
    HelesicPetr
    Hi @BrianToussaint
    PetrH
