Advanced Search Criteria ordered alphabetically and case- sensitive
Hi all,
The Criteria in the Advanced Search is ordered alphabetically and also its case sensitive.
So if there is a criteria with lowercase it will be added after all the other.
Is there a way to remove the case-sensitive and only have them ordered alphabetically?
Alex
Alex,
You may want to open a Support case for this, to investigate.
What search criteria are you seeing this with then?  Screenshots?
Are language/locales involved here - like you might see it with a particular locale, but not another?
That might help narrow down the scope of investigation for Support.
