jbailey
18-Opal
AfterEDRloader - use the CAd Doc Number instead of name to generate additional file name
Is there a way to use AfterEDRLoader to pull the number of the cad doc for the additional file instead of the name field?
TomU
jbailey
jbailey18-OpalAuthor
18-Opal
So would I use epmdoc_number?
Yes
Here is the AfterEDRloader.java updated to use Number instead of File Name.
Rename the file to remove .txt
