Dec 5, 2023 5:25 AM UTC
[API] SolidWorks check in/out in Windchill
Hi Guys,
I want to check in/ check out the Solid Works model/folder in Windchill through API using c#. Is there any source code or documentation available?
Thank you
Dec 11, 2023 6:19 AM UTC
Hi, Thank you for providing reference documents.
This document contains rest services API, is it the only one document I need to follow for the task I want to achieve?
Do you have any reference code for check in/out solidworks files in Winchill using API (c#)? That would really help me out to start with.
Thank You.
avillanueva
23-Emerald II
Dec 11, 2023 2:54 PM UTC
Are you not looking to use the Workgroup Manager? Or are you looking to trigger those actions via code?
Dec 11, 2023 3:06 PM UTC
Yes, I am looking to trigger those actions via code (c#).
