API to attach (txt, xml..etc) as attachments to EPMDocument
Is anyone aware of how to programmatically attach the files (xml, txt) etc to the CAD Attachments section??
VladimirNAnswer
See the following discussion - "How to programatically add a document to attachments section?": https://community.ptc.com/t5/Windchill/How-to-programatically-add-a-document-to-attachments-section/td-p/801940
VladimirN24-Ruby IVAnswer
18-Opal
August 30, 2023
@JM_10276355 ,
I've written utilities that can both attach and remove attachments from EPMDocuments. The remove does it without iterating the EPMDocument.  So yes, this is doable.
How about posting more specifics regarding how EXACTLY you would like this to work?  Is this something a user is doing from the WIndchill UI?  Is it something and admin is doing without the Windchill UI?  What's the use case?
18-Opal
October 26, 2023
Hi @JM_10276355,
The following code snippet can be used to update the content.
ApplicationData appData = ApplicationData.newApplicationData((FormatContentHolder) epmDocument);
appData.setRole(ContentRoleType.SECONDARY);
appData = ContentServerHelper.service.updateContent(epmDocument, appData, "file.txt");
