API to create Link between WTPart and EPMDocument
Hi All,
I am trying to create a Link between WTPart and EPMDocument objects by using below code,
it's executed without error but it not create any kind of link in between these two objects.
is any one tried to create Link between WTPart and EPMDoc.
Please review below code and suggest the correct way to create this type of links.
  1. System.out.println("Getting the epmdocument");
EPMDocument source = getEPMDocument(); //getEPMDocument method returns me object of EPMDoc type
System.out.println("Getting the WTPart");
WTPart target = getWTPart(); // getWTpart method returns me object of WTPart type
System.out.println("Creating the link between wtpart and epmdocument");
int buildType = 1;
source = (EPMDocument) WorkInProgressHelper.service.checkout(source,WorkInProgressHelper.service.getCheckoutFolder(),"").getWorkingCopy();
EPMBuildRule link = EPMBuildRule.newEPMBuildRule(source, target);
PersistenceServerHelper.manager.insert(link);
System.out.println("Link has been created");
WorkInProgressHelper.service.checkin(source,null);
System.out.println("Done...");
Vivek
20-Turquoise
June 16, 2016
Vivek: I have used the following to create a link between a wtpart and an empdocument drawing:
EPMDocument epmDoc = getEPMDocument(); //getEPMDocument method returns me object of EPMDoc type
WTPart wtPart= getWTPart(); // getWTpart method returns me object of WTPart type
Folder checkedout = WorkInProgressHelper.service.getCheckoutFolder();
WTPart wtPartWC = (WTPart) WorkInProgressHelper.service.checkout(wtPart, checkedout, "").getWorkingCopy();//checkout and get the working copy
From https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS188209
wt.epm.build.EPMBuildRule.newEPMBuildRule(EPMDocument source, WTPart target, int buildType)
buildType parameter comes from the following:
1.         Owner Link : builtType = EPMBuildRule.BUILD_ATTRIBUTES | EPMBuildRule.BUILD_STRUCTURE | EPMBuildRule.CAD_REPRESENTATION;
2.         Image Link : builtType = EPMBuildRule.CAD_REPRESENTATION;
3.         Contributing Image Link : builtType = EPMBuildRule.BUILD_ATTRIBUTES | EPMBuildRule.CAD_REPRESENTATION;
4.         Contributing Content Link : builtType = EPMBuildRule.BUILD_ATTRIBUTES;
EPMBuildRule buildRule = EPMBuildRule.newEPMBuildRule(epmDoc, wtPartWC, EPMBuildRule.BUILD_ATTRIBUTES);
buildRule = (EPMBuildRule)PersistenceHelper.manager.save(buildRule);
WorkInProgressHelper.service.checkin(wtPartWC, "Associated the Drawing");
Vivek, i think Randy is right. Please be informed that while a EPMDocument get associated with a WTPart, only the WTPart will get iterated. Hence we check out WTPart to associate them.
vuchekar1-VisitorAuthor
Hi Kavin,
Yes Randy was correct. i am able to cretae link between WTPart and EPMDocument after check out the WTPart.
Hi Randy,
Thanks for your help.
I have another question related to links, which type of link present between Assembly and it's drawing.
which Api i have to use to create link between assembly and it's drawing?
Any help will be grate.
Vivek
