11-Garnet
Apr 5, 2017 8:59 AM UTC
API to get the product serial number effectivities associated with a WTPart
I have a set of WTParts whose serial number effectivity value has been entered wrong. I want to delete them using API.
What is the API to access the serial number effectivities associated with WTPart?
I know that I can delete the serial numbers using the following API:
PersistenceHelper.manager.delete((ProductSerialNumberEffectivity) serial);
But I am having trouble getting the ProductSerialNumberEffectivity for a particular WTPart.
Please help.
Thanks in advance
ShirishMorkhade
Apr 7, 2017 11:48 AM UTC
Hi Srinivas Morla
You may want to try this. I used this way back and sharing for your reference as it is. So you may need to modify and test it as per your business use case.
QueryResult qr2 = wt.effectivity.EffectivityHelper.service.getEffectivities(prt);    // Object of WTPart whose effectivity you want to delete...
while (qr2.hasMoreElements()) {
  Object obj = (Object) qr2.nextElement();
  System.out.println("Object-> " + obj.toString());
  if (obj.getClass().isAssignableFrom(wt.part.ProductSerialNumberEffectivity.class))
       System.out.println( " Found Serial Numbered Effectivity" );
       wt.part.ProductSerialNumberEffectivity serial = (wt.part.ProductSerialNumberEffectivity)obj;
       String sRange=serial.getRange().getStart().toString().trim();
       System.out.println("Start Range is --->"+sRange);
       if (serial.getRange().getEnd().toString().trim() != null)
            sRange += " - " + serial.getRange().getEnd().toString().trim();
       else
            sRange += " - " + "<open>";
       // System.out.println(" Range: " + sRange);
       // System.out.println(" Effectivity Type: " + serial.getEffContext());
       System.out.println("*** Trying to delete Serial Effectivity ***");
       PersistenceHelper.manager.delete(serial);     // be careful here. Your deleting something....
       System.out.println("*** SerialNumbered Effectivity for WTPart: "+prt.getNumber()+" is succesfully deleted ***");
  else
       System.out.println( "Effectivity other than Serial..." );
I hope this helps you.
Shirish
smorla11-GarnetAuthor
11-Garnet
Apr 13, 2017 5:06 AM UTC
Hi Shirish
I tried this code - I am faced with another unusual problem. I notice that the EffectivityHelper.service.getEffectivities(prt); API retrieves only WTDatedEffectivity objects, that is, according to your code I always get "Effectivity other than serial" printing in the console.
I thought the API was meant for date effectivity only, until I wrote a query to retrieve all serial number effectivity (just to check) using the following query:
QuerySpec qs = new QuerySpec(wt.part.ProductSerialNumberEffectivity.class)
QueryResult qr = PersistenceHelper.manager.find(qs);
This gave me a null result. I have several WTParts with serial number effectivities associated with them - I can see them in the Service Effectivity UI as well. But, for some reason, I am unable to retrieve them using API.
What could be the reason for this?
