8-Gravel
Apply Assigned Usage Expression, Latest, View and State Filter on a Part BOM Structure
I'm looking to apply Option Choice filter, combined with Latest, View and State Filter on a WTPart BOM Structure in Windchill api ust like how we do in Windchill UI. Can anybody help?
​@HelesicPetr ​@avillanueva
18-Opal
Hi ​@VM_13704617 ,
Would you like to retrieve the information through an API, or are you looking to implement it in the UI?
Fadel
23-Emerald II
Use Rest services getPart structure than you can put all needed criteria in Navigation criteria on the fly or  use existing filter saved on UI
Buiꓘa
HelesicPetr
Hi ​@VM_13704617
I tried to read a users filter settings in the GWT enviroment (WTPart structure) many times and I always gave up.
It is not easy to find how the information is read in the backend .
I could not find it.
I usually create an own wizard with an own logic where I could do anything :D
PetrH
