Feb 29, 2024 1:21 PM UTC
Assembly Mode - Remove option "inseparable"
I don't find a solution to remove in Windchill (ver. 11.1) the option "inseparable" in the fied Assembly Mode (internal name: partType).
I'd like to have only "separable" and "component".
Somebody has a solution to do this?
Thx
HelesicPetr
Mar 1, 2024 9:20 AM UTC
Hi @Alberto
You can not change it in the UI.
You need to change resource bundle info definition in enumcustomization
https://www.ptc.com/en/support/article/CS366297
You just need to find right file where the values are written
codebase/wt/part/
PartTypeRB.RB.rbInfo / PartTypeRB.RB.ser
rbInfo is text file where the definition is defined. ser file is final compiled file that is used by system.
I would advice to hide the value. Never ever delete it because it is OOTB.
PetrH
Fadel
23-Emerald II
Feb 29, 2024 5:42 PM UTC
to edit this entries in resources you need Enum customize , the best way to achieve this is to add a new legal value constraint with only 2 entries separable|component
Buiꓘa
Alberto10-MarbleAuthor
Mar 1, 2024 7:02 AM UTC
Thx for your replay but it means to have the new legal value only for the new document, right? The old data will have only the current parameter.
