3-Newcomer
attachment.js causing issue when downloading the customized reports in windchill UI
I am using Windchill PDMLink Release 13.0 and Datecode with CPS 13.0.2.1
When I m downloading the customized report in Windchill 13, attachment.js is getting run and causing the download failure. Please check it on priority
    Community Moderator
    Hi @LP_10703440,
    Thank you for your question.
    Your post appears well documented but has not yet received any response.
    Could you please provide additional details like which browser and version you're using when the issue occurs?.
    Does the download fail for all customized reports or only a specific one? or any error messages or logs generated when the download fails?
    I am replying to raise awareness. Hopefully, another community member will be able to help.
    Anurag
    joe_morton
    What customized report are you downloading?
