Attribute of type real number
Hi community,
I want to get the value of an attribute in the code below. The attribute is of type real number, defined by the com.ptc.core.meta.common.FloatingPoint class. When I try to get the value it doesn't give me any results. Can you help me?
 com.ptc.core.lwc.server.PersistableAdapter obj = new com.ptc.core.lwc.server.PersistableAdapter(part,null,java.util.Locale.getDefault(),new com.ptc.core.meta.common.UpdateOperationIdentifier());
 obj.load("SURFACE_M2 ");
 SURFACE_M2 = (com.ptc.core.meta.commmon.FloatingPoint) obj.get("SURFACE_M2");
HelesicPetr
Hi @smcvr
Wrong name definition >D
You added a space in the end. Remove it.
PetrH
Fadel
23-Emerald II
October 2, 2023
what is the windchill version ?
Buiꓘa
smcvr15-MoonstoneAuthor
Hi @Fadel
Use Windchil  12.0.2.9
HelesicPetr
Hi @smcvr
PetrH
Hi @HelesicPetr,
 Thank you so much for your help 😄
HelesicPetr
@smcvr Four eyes see more than two 😄
PetrH
