Feb 16, 2017 1:00 AM UTC
AuthenticationException and wt.httpgw.HTTPAuthentication - HTTP login failed: client host = 171.71.189.172
When I run the API in test server, all is ok, but after applying to stage server(same production server), there is a error "wt.method.AuthenticationException", in method log file, the error info is "[RMI TCP Connection(14)-171.71.189.172] wt.httpgw.HTTPAuthentication  - HTTP login failed: client host = 171.71.189.172", who can help me? "171.71.189.172" is the server IP.
Thanks.
White
2-Explorer
Feb 16, 2017 3:09 PM UTC
Do you have the password hardcoded in your code? Do you have a different authentication mechanism in your staging? - Like SSL, SSO ?
WhiteChen1-VisitorAuthor
Feb 16, 2017 5:25 PM UTC
Thank you for your reply. The difference between test server and stage server is that stage server have SSL, how can I solve it and make my API worked on stage server?
2-Explorer
Feb 16, 2017 6:02 PM UTC
Could you paste the rest of the stack trace here? If you have not imported the certificate to java keystore, you have to do that using the Keytool
