Mar 19, 2024 8:01 AM UTC
Automate creation of representation using local archive PDFs for EPMDocument
Hello All,
I followed Article - CS216138 and configured an option to upload local files as representations for an EPMDocument from the UI wizard (I am using Windchill 12.0.2.14). I am wondering if there is any way to automate this upload process. Support for representation upload using the loadfromfile framework is only available for WTPart, not for EPMDocument. Does anyone have any suggestions? Thanks.
d_grahamAnswer
18-Opal
Mar 21, 2024 12:54 PM UTC
@TR_10627971
@HelesicPetr  is correct. That’s what you need to do.
David
18-Opal
Mar 19, 2024 11:43 AM UTC
@TR_10627971
This is doable for sure.
Do you know Java and the Windchill database architecture for how content is managed.
Are you adding these PDFs to an existing rep or are you replacing rep PDFs with these “local” PDFs?
What’s the use case?
One off bulk load or somehow triggered?
David
Mar 21, 2024 10:51 AM UTC
Hello @d_graham ,
Thank you for your response. I'm familiar with the Windchill database architecture for content and have some Java experience.
I want to clarify that I'm not looking to add these PDFs to an existing representation.
Instead, I'm addressing a post-migration bulk load scenario. In this context, none of the migrated .drw objects will have any representations.
Our objective is to upload representation PDFs for these EPMDocument objects using local PDFs. Could you please provide guidance on how this can be achieved?
Thank you.
HelesicPetr
Mar 21, 2024 11:00 AM UTC
Hi @TR_10627971
If you need to create new representation use this
DerivedImage.newDerivedImage();
Then link this representation to the EPMDocument and attach the local pdf file as an ApplicationData
PetrH
