Automatically Transfer Documents from Windchill ProjectLink to another Windchill Instance
How to automatically transfer data (documents) from windchill project link to another windchill instance?
7-Bedrock
July 28, 2023
  1. Import/Export
  2. Windchill Bulk Migrator WBMFF
  3. Using Java API
ScottMorris
can you explain more about the second windchill system?
  • are the two running independently?
  • how frequently would you need to sync the documents from one system to another?
  • do you want to collect historical versions of the documents?
  • will the docs go from project to project or project to product/library?
from @IvanFeofilov response, import/export is the quickest way to go, but if you need to maintain parity between systems, you might want to look at Windchill Packages.
