Based on IBA value how to get the document soft type using QuerySpec
Hi All,
In Windchill 12.1 Vesion below API is not supported and any alternative API?
SearchCondition sc = TypedUtility.getSearchCondition("WTYPE|WTDocument|my.softType", true);
My requirement is to get wtdocument softype as searchcondition then add to QuerySpec.
Vishvanatha
HelesicPetr
Hello @VR_10417596
Does the API exists? use it. Not supported means nothing.
Also you can try alternate one or write own method to crete it.
WCTypeIdentifier typeID = CreateAndEditWizBean.newWCTypeIdentifier("WTYPE|WTDocument|my.softType");
this one is from the mentioned class CreateAndEditWizBean
 public static final WCTypeIdentifier newWCTypeIdentifier(String typeInput) {
 WCTypeIdentifier var1 = null;
 if (typeInput != null && !"".equals(typeInput)) {
 try {
 var1 = (WCTypeIdentifier)IDENTIFIER_FACTORY.newWCTypeIdentifier(typeInput);
 Class.forName(var1.getClassnameFromTypename());
 } catch (Exception var3) {
 if (log.isDebugEnabled()) {
 log.debug(" in getTypeIdentifier() trying to create WCTypeIdentifier from type: " + typeInput);
 var1 = null;
 return var1;
PS> here is example how to create SearchCondition
		ModeledTypeModel atmodel = new ModeledTypeModel();
		try
		SearchCondition sc = atmodel.getSearchCondition(typeID,true);
		} catch (WTException e)
			throw new RuntimeException(e);
PetrH
HelesicPetr
Hello @VR_10417596
 try {
 var1 = null;
 return var1;
		try
PetrH
Hi Helesic,
I have tried this and its returning the soft type model type.
Vishvanatha
HelesicPetr
Hi @VR_10417596
And can you share a example how it looks like ?
What are real data returned and what do you really expect ?
PetrH
