Best way to download files from Windchill Server to client
I'm looking to download a zip from my windchill server(temp location) to the client machine.
The zip was actually created as a result of an custom action.
So basically, when I click on the action a zip should get downloaded, that's my requirement.
Please suggest me your ideas or share me any existing solution.
Many thanks in advance.
HelesicPetr
Hi @MV_10441462
depends how do you start your function.
usually you get request and get the outputstream from it and flush (send) the data to the client as @avillanueva's example shows you. .
here is short snip with a zipStream but you need to learn how to add files to the zip stream
HTTPResponse resp; // you need to get respons from commandBean or whereever HttpServletResponse response = nmCommandBean.getResponse();
ByteArrayOutputStream zipOut = new ByteArrayOutputStream();
CheckedOutputStream checksum = new CheckedOutputStream(zipOut, new Adler32());
ZipOutputStream zipOutputStream = new ZipOutputStream(new BufferedOutputStream(checksum));
InputStream contentStream = ContentServerHelper.service.findContentStream(appDatatToZip);
		// definice filename s cestou v zip
String fileZipEntry = appDatatToZip.getFileName();
addStreamToZip(fileZipEntry, zipOutputStream, contentStream); // annother sub method where the content is writen to zip
zipOutputStream.close();
OutputStream output = resp.getOutputStream();
resp.setHeader("Content-disposition", "attachment; filename=zipDownloadFile.zip");
resp.setHeader("Content-Type", "application/zip");
output.write(zipOut.toByteArray()); // zip stream written to the respons outputStream
output.flush();
output.close();
PetrH
avillanueva
23-Emerald II
I did this with a JSP tied to that custom action:
BOMExportExcelUtility excelUtil=BOMExportExcelUtilityImpl.createBOMExportExcelUtility();
 //7. Sub-module create Excel File for user download
 response.reset();
 excelUtil.createExcelFile(response.getOutputStream(),sheet1,sheet2);
 ServletOutputStream outs = response.getOutputStream();
 response.setHeader("Content-type","application/ms-excel");
 String version=VersionControlHelper.getVersionIdentifier((Versioned)bom).getValue();
 if (version.indexOf('.')!=-1)
 version=version.substring(0, version.indexOf('.')); //just get first part
 String filename=bom.getNumber()+version;
 response.setHeader("Content-disposition","attachment; filename="+filename+".XLS");//should prompt for download
 excelUtil.writeFile();
 //8. Return response to user's browser session.
 outs.flush();
 outs.close();
This is the section where my code creates an XLS file and streams it back to the client. User downloads the file.
HelesicPetr
Hi @MV_10441462
example  from @avillanueva is very good one how to download file.
I would add that you need to write own sollution.
Create zip in java
Collect files from Windchill
Add files to the zip
push the zip stream to the client user
PetrH
Hi @HelesicPetr
Can you please help me with the snippet to push the zip stream to client user?
