11-Garnet
Call DataUtility uder Text box that is rendered by Table builder
Version: Windchill 13.0
Use Case: Call DataUtility uder Text box that is rendered by Table builder
Description:
Call DataUtility uder Text box that is rendered by Table builder.
public Object buildComponentData(ComponentConfig config, ComponentParams params) throws Exception {
Map<String, GuiComponent> data = new HashMap<String, GuiComponent>();
GuiComponent comp = new TextBox();
((TextBox) comp).setName("editABC");
((TextBox) comp).setId("editABC");
((TextBox) comp).setRequired(true);
((TextBox) comp).setWidth(30);
data.put("editABC", comp);
LOGGER.trace("***  editABCTableBuilder  buildComponentData OUT");
return data;
@Override
public ComponentConfig buildComponentConfig(ComponentParams params) throws WTException {
ComponentConfigFactory factory = getComponentConfigFactory();
AttributePanelConfig attributePanelConfig = factory.newAttributePanelConfig();
GroupConfig groupConfig1 = factory.newGroupConfig("editABC","Edit ABC", Integer.valueOf(1));
AttributeConfig editABC = factory.newAttributeConfig();
editABC.setId("editABC");
editABC.setLabel("AfterMarket ABC");
editABC.setRequired(true);
groupConfig1.addComponent(editABC);
attributePanelConfig.addComponent(groupConfig1);
LOGGER.trace("*** editABCTableBuilder  buildComponentConfig OUT");
return attributePanelConfig;
18-Opal
Hi @AA_9841156,
I understand that you want to build the Attribute Panel.
Do you want to call a Data Utility on one of the attribute present within the Attribute Panel group?
You can use the following API
editABC.setDataUtilityId("x");
where x represents the selector value used to register the Data Utility.
11-Garnet
Hi @TDT .
Actually I am trying to create Attribute Panel in which two thing only .one is label and second i want Textbox in front of that and i want call datautility there.
11-Garnet
I tried already editABC.setDataUtilityId("x") but its not hitting dataUtility
