Can we filter by state or display state in 'Find Affected Objects' wizard when creating a CR?
1. Can we display a state column in the Find Affected Objects window?
or
2. Can we add a filter and filter by state?
or
3. Can we use baseWhereClause="(state.state='PRODUCTION')" in jsp file and customize, so that only production state objects are returned?
HelesicPetr
Hi @RG_10753677
Add the state to the view in a view customization
the state is already there so you need to just show it
PetrH
Thank you so much, this works for my use-case temporarily.
Long-term, I am looking for way to restrict users from selecting non-prod state affected objects, or WC to return only prod-state objects, that way users can click on 'Select all' checkbox in the results table header, instead of grouping/sorting the results by state and selecting each object manually,
Can you try like below.
Go to codebase\pickerAttributes.xml file
    <ComponentID id="compID">
        <ObjectType id="TYPE">
            <SearchCriteriaAttributes>
                <Attributes>
                    <Name>internalName1</Name>
                        <DisplayName>DN1</DisplayName>
                            <IsSearchable>true</IsSearchable>
                </Attributes>
                <Attributes>
                    <Name>internalame2</Name>
                </Attributes>
            </SearchCriteriaAttributes>
        </ObjectType>
    </ComponentID>
use the compID in your jsp picker
<wctags: itemPicker
searchResultsViewId="<custom>.view"
displayAttribute="<list of attribute's internal names separated by commas>"
componentId="compID"
