Can we show a Attribute having drop down values on Task page ?
Hi All,
My requirement is to show a custom Attribute on Analyse Change request Task page of change Request.
In this task, assignee can choose the correct values according to his choice from drop down values.
Any Idea ?
Vivek
2-Explorer
February 17, 2017
This is possible by creating a resource file and  defining the resource file as the java class type for the variable. PTC has KB article on this https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS36017&art_lang=en&posno=1&q=workflow%20task%20dropdown&source…
The only challenge is keeping the value in sync with the enumerated list which you define in the type and attribute manager.
Just to add few points.
  1. The resourcebundle file can be updated using enumCustomize.
  2. The solution mentioned in PTC article required Info Modeler.
kaushik
HelesicPetr
Hi @KD_01
The InfoModeler is not needed if you use IDE to compile the java code with annotations for example Eclipse atc.
PetrH
