Can we use (PersistenceManagerEvent.PRE_STORE) event for Change notice creation ?
  • September 9, 2024
  • 2 replies
  • 756 views
Hi BjoernRueegg,
Can we use same ( PersistenceManagerEvent.PRE_STORE)  event for Change notice creation ?
Because I want manipulate char length of one of String type IBA before CN creation.
If not then could you please suggest the right event.
Hi
Please refer to article https://www.ptc.com/en/support/article/cs43313 for How to determine which event to listen for in Windchill
Community Moderator
September 13, 2024
Hello @@_1647
It looks like you have a response on your topic. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
HelesicPetr
Hi @@_1647
What exactly do you want to do with IBA length?
Throw exception to a user that length is over a limit?
It is possible to use the PRE_STORE event, but I would use different way. by changing a wizard processor where is a pre-operation method.
PetrH
