8-Gravel
change request affected objects
Version: Windchill 12.0
Use Case: While editing the Change Request adding new affected objects under select affected object, suppose there is 2 affected objects already present for the change request we are adding 1 new object.
Description:
The problem faced is while fetching these affected object through code using ChangeHelper2.service.getChangeables(changeRequest) inside editFormProcessor only able to get the 2 affected object, I need to check all the affected objects(existing + newly added) as well as just newly added object.
d_grahamAnswer
18-Opal
@NG_10595539 ,
You can't expect ChangeHelper2.service.getChangeables(changeRequest) to get the newly added objects because at this point in the process they are not added yet.  They are not linked to the CR at this point and therefore there is no link in the dB that getChangables() method can query.
BTW, can you tell us exactly what you are intending to check when checking the newly added objects?
d_graham18-OpalAnswer
18-Opal
@NG_10595539 ,
8-Gravel
hi @d_graham ,
need to check newly added WTDocument for the affected object.
18-Opal
What does that mean?
WTDocuments don't have affected data.
