Check in form in Windchill 11.0 vs Intralink 3.4
Customer Question
We are into our first week of using the new Windchill system, and so far we are liking it. However, I do have one question for you. Previously, in Intralink 3.4, we were able to locate a specific check in form, and delete it along with the part iterations introduced, effectively undoing the check-in.
So far I have not found a way to do this using Windchill. I would like to be able to find a specific check-in, see what parts were modified, and delete the latest iteration of those parts.
There is no check-in form to worry about. Depending upon access control and database integrity considerations, you can simple select delete from the Actions of the object page (or right mouse from a table view).
Note that individual iterations can often be deleted, but all versions will often not work because of integrity violations.
