Feb 19, 2019 6:21 PM UTC
Code to check roles in a workflow
I have the code (below) to check if a role has someone assigned to it or not.  What I need is how to change the code to check for two different roles to make sure that they are both assigned.
wt.workflow.work.WfAssignedActivity act = (wt.workflow.work.WfAssignedActivity) self.getObject();
	wt.workflow.engine.WfProcess pro = (wt.workflow.engine.WfProcess) act.getParentProcess();
	wt.team.Team t = wt.team.TeamHelper.service.getTeam(pro);
	java.util.Map members = t.getRolePrincipalMap();
	java.util.Set keys = members.keySet();
	java.util.Iterator itr = keys.iterator();
	while (itr.hasNext()) {
		wt.project.Role role = (wt.project.Role) itr.next();
		System.out.println("Role-=-=-=" + role);
		if (role.toString().equalsIgnoreCase("MyCustomRole")) {
			java.util.ArrayList users = (java.util.ArrayList) members.get(role);
		//If there is no user in MyCustomRole role throw exception
			if (users.isEmpty()) {
			throw new Exception("Select user for " + role.getDisplay());
Feb 19, 2019 6:36 PM UTC
You can consider something like that:
java.util.ArrayList<String> rolesToCheck = new java.util.ArrayList<String>();
rolesToCheck.add("MYCUSTOMROLE");
rolesToCheck.add("MYCUSTOMROLE2");
	if (rolesToCheck.contains(role.toString().toUpper()))) {
The roles must be uppercase and internal value.
That way, you can check as many roles you want.
Florent
Feb 19, 2019 7:27 PM UTC
Hello Florent,
I am using the internal name for my roles and capitalized them in my first line of code.  However my roles are not all capitalized.
I got the following error when checking syntax....
Checking Syntax...
Checking Syntax...
D:\ptc\Windchill_11.0\Windchill\temp\WfExpression188770479.java:56: error: illegal start of expression
1 error
Syntax check complete.
Brian
Feb 19, 2019 7:38 PM UTC
Sorry, I made a mistake.
Try replacing the first line with
Jan 5, 2023 12:11 PM UTC
Hi;
How can I assign my own desired participants to a role with code?
