Control not coming out of Apply-Service webject
HI all,
I am  using Apply-Service webject to fetch alternates from part. Below is the code snippet.
<ie:webject name="Apply-Service" type="OBJ">
    <ie:param name="INSTANCE"   data="${FORM[]instance[]}" default="windchill"/>
    <ie:param name="SERVICE"   data="wt.part.WTPartHelper"/>
    <ie:param name="METHOD"   data="getAlternatesWTPartMasters"/>
    <ie:param name="STATIC"   data="false"/>
    <ie:param name="GROUP_IN"   data="parts"/>
    <ie:param name="ARG"   data="wt.part.WTPartMaster=masterReference" delim=";"/>
    <ie:param name="GROUP_OUT"   data="alt"/>
</ie:webject>
For one particular part , the code executes till last line i.e. "<ie:param name="GROUP_OUT"   data="alt"/>" . After that the control is not coming out of the webject for 25 minutes. What could be the reason ? Please help.
