Could not find stored procedure'wt_get_next_sequence_xxx'
Hi All,
Trying to create a new sequence for WTPart subtype referring to Article - CS42301.
A new sequence got created successfully. Replaced the sequence in OIR.
When try to create new part it giving error: Could not find stored procedure'wt_get_next_sequence_xxx'.
Anyone who has tried this could let me know the modifications to be done.
Thanks in advance
Durga
HelesicPetr
Hi @Durga
Error tells you that procedure does not exist.
Have you checked if the procedure is created in database with correct name?
This is first thing I would check.
PetrH
BenPerry
@Durga,
https://www.ptc.com/en/support/article/CS42301 is wrong.  The part in RED text below is missing from the article.  This is a modified example using custom sequence wt_sequence_MY_CUSTOM_SEQ as an example.  Please confirm whether this works for you.
CREATE TABLE pdmlink.wt_sequence_MY_CUSTOM_SEQ (dummy CHAR(1),value BIGINT IDENTITY(0366000, 1))
go
CREATE PROCEDURE pdmlink.wt_get_next_sequence_wt_sequence_MY_CUSTOM_SEQ @returnValue BIGINT OUTPUT
AS
INSERT pdmlink.wt_sequence_MY_CUSTOM_SEQ (dummy) VALUES ('x')
SELECT @returnValue = SCOPE_IDENTITY()
go
HelesicPetr
Hi @BenPerry
You right if the name of your sequence is "wt_sequence_MY_CUSTOM"
if the name is just "OWN" you don't need to add the wt_sequence string
for example:
CREATE TABLE OWN_seq (dummy CHAR(1),value BIGINT IDENTITY(0366000, 1))
go
CREATE PROCEDURE [wcuser].[wt_get_next_sequence_OWN_seq]
AS
INSERT OWN_seq (dummy) VALUES ('x')
GO
So the article is not generally wrong. PTC could correct it if you send a feedback.
PetrH
BenPerry
@HelesicPetr,
Yes, the article is actually wrong.  In the example for creating the table/etc, it calls the sequence "wt_sequence_test".  But in the example OIR, the sequence name is just "test".
If the correct example sequence name is "wt_sequence_test", then the OIR example needs to be adjusted.  And the CREATE PROCEDURE needs to be adjusted to "wt_get_next_sequence_wt_sequence_test".
The article is not fully correct and has led to many confused people.  including @Durga and some of my colleagues.
My db has a name windchill_inst, so we need to include that when defining the table and procedure.
CREATE TABLE windchill_inst.wt_sequence_SPARTID_seq (dummy CHAR(1), value BIGINT IDENTITY(4000799, 1))
go
CREATE PROCEDURE windchill_inst.wt_get_next_sequence_SPARTID_seq @returnValue BIGINT OUTPUT
AS
INSERT windchill_inst.wt_sequence_SPARTID_seq (dummy) VALUES ('x')
go
