Aug 20, 2018 4:13 AM UTC
Count of all objects in all object types in Windchill
Hi All,
If I want to get the count of all the objects in all object types how would I be getting the same ?
Is there any nested query or program for the same. Please let me know about it
Best Regards,
Aditya
3-Newcomer
Aug 20, 2018 12:18 PM UTC
You should take a look on the QueryBuilder  / Reports.
Depending on whether you want the count per sub type, you may have to  join the table per typedefinition.
Florent
aachanta15-MoonstoneAuthor
Aug 22, 2018 2:24 PM UTC
Hi
How would I get the results if I want to get all the document, part objects, folder count, change request and other objects which can be versionable or non versionable in one single query ?
is it possible for us to have one script for that ?
If yes can you please let me know like how can that be done.
Best Regards,
Aditya
avillanueva
23-Emerald II
Aug 20, 2018 1:37 PM UTC
Do you have access to the database? Toad can should you table counts very easily.
22-Sapphire I
Aug 20, 2018 4:30 PM UTC
Run simple queries against the database for each object type.
For CAD:
select count(*) from epmdocumentmaster to get all unique (e.g. 123.prt, 455.prt).
select count(*) from epmdocument to get all versions (e.g. 123.prt A.1, 123.prt A.2, 123.prt B.1 etc.).
For WTDocuments:
select count(*) from wtdocumentmaster to get all unique
select count(*) from wtdocument to get all versions
For WTParts if used:
select count(*) from wtpartmaster to get all unique
select count(*) from wtpart to get all versions
Aug 22, 2018 6:39 AM UTC
Hi Mike,
Best Regards,
Aditya
22-Sapphire I
Aug 22, 2018 2:54 PM UTC
For this, I'd suggest to query (in Windchill, not directly to the database) as count(*) against wtObject, and then apply Group By to the Object Type.  Runs into a bit more but can be done.
May lead to a small consulting gig.
