6-Contributor
February 10, 2023
Creating Publishing rules in Windchill
  • February 10, 2023
  • 8 replies
  • 2720 views
Hello everybody,
I am trying to make my first steps in creating publishing rules but I am not really sure what to do. Actually I am using this .xml code.
<?xml version="1.0" encoding="UTF-8"?>
<rules xmlns="http://www.ptc.com" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.ptc.com PublishRulesSchema.xsd" >
	<authoring-application name="PROE">
		<additional-files name="standard_files">
			<file type="dxf" display-label="DXF" default="true" output-prefix="dxf"/>
		</additional-files>
		<publish on="checkin" additional-files="standard_files">
			<param-set-ref name="Additional Files Post Publish for Released Document"/>
		</publish>
		<publish on="create-representation" additional-files="standard_files">
		</publish>
		<param-set name="Additional Files Post Publish for Released Document">
			<post-publish name="delegate">com.ptc.wvs.server.publish.AdditionalFilesPostPublishDelegate</post-publish>
			<post-publish name="name">TEST_{AUTHORING_APP}_{EPM_NUMBER}_{ADDITIONAL_FILE_SECONDARY_EXTENSION}</post-publish>
			<post-publish name="additional-file-secondary">.*\.(igs|stp|dxf)</post-publish>
			<post-publish name="published-content-link">Released</post-publish>
		</param-set>
	</authoring-application>
</rules>
First of all can somebody explain me the difference between the parameters DefaultPostPublishDelegate,
EPMPostPublishDelegate and DDPostPublishDelegate?
My target is to generate dxf data in a specific number range of parts during the check-in. Can somebody help me with my project? I am actually using Windchill 12.1 with creo_view_adapters.
Thanks in advance!
Chris
HelesicPetr
Hi @CC_10081426
The general explanation for the delegate is in help
WVSPublishRules/WVSPublishRulesPostPublishDefault
Here is example how to define DXF and condition with filename
<?xml version="1.0"?>
<rules evaluate-rules-on-republish="true"
	xsi:schemaLocation="http://www.ptc.com PublishRulesSchema.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.ptc.com">
			<!-- only default='true' files will be generated at this time -->
			<file output-prefix="step" default="false" type="step" display-label="STEP"/>
			<file output-prefix="iges" default="false" type="iges" display-label="IGES"/>
			<file output-prefix="dxf" default="false" type="dxf" display-label="DXF"/>
			<file output-prefix="cgm" default="false" type="cgm" display-label="CGM"/>
			<file output-prefix="pdf" default="false" type="pdf" display-label="pdf"/>
		</additional-files>
		<additional-files name="released_drawing">
			<file output-prefix="dxf" default="true" type="dxf" display-label="DXF"/>
			<file output-prefix="pdf" default="true" type="pdf" display-label="pdf"/>
		</additional-files>
		<condition name="is_released_drawing">
				<and>
					<attribute name="epmdoc_CADName" regex=".*\.drw" /> <!-- HERE YOU CAN DEFINE YOUR CONDITION WITH SPECIFIC FILENAME -->
					<attribute name="epmdoc_lifeCycleState" value="Released"/>
				</and>
		</condition>
		<if condition="is_released_drawing">
			<publish on="checkin" display-label="Released Drawing" additional-files="released_drawing"/>
		 <publish on="create-representation" display-label="Released Drawing" additional-files="released_drawing" />
		 <publish on="schedule" display-label="Released Drawing" additional-files="released_drawing"/>
		 <publish on="unknown-source" display-label="Released Drawing" additional-files="released_drawing"/>
		</if>
		<publish additional-files="standard_files" on="checkin"/>
		<publish additional-files="standard_files" on="create-representation"/>
		<publish additional-files="standard_files" on="schedule" />
		<publish additional-files="standard_files" on="unknown-source" />
</rules>
PetrH
6-Contributor
February 13, 2023
Hello PetrH,
thanks for the fast reply! This code helps a lot. But in general the problem is that we have a .drw file out of creo wich includes 2 sheets. I only need a .dxf fie out of the second sheet. Is there a possibility to limit a .dxf export?
Thanks in advance.
Best regards.
HelesicPetr
Hello @CC_10081426
Unfortunately there isn't OOTB possibility to limit the DXF sheets in additional files.
I needed many years ago, but I didn't find any way how to achieve it.
I decided to use an another way. Users had to create a DXF attachment file from second sheet.
Users used a macro to do the action without losing time in a Creo..
I set a control mechanism to check if the attachment is out-of-date and force users to regenerate the DXF attachment.
PetrH
20-Turquoise
February 13, 2023
HelesicPetr
Hi @RandyJones
Good one, but archived it's a pity.
If @CC_10081426 would like to rise the idea he needs to create a new one and try to get enough votes from others.
PetrH
20-Turquoise
February 13, 2023
@HelesicPetr wrote:
Hi @RandyJones
I see 😞
