May 28, 2024 1:57 PM UTC
Customization: Create an individual Design Tab for a Change Request child object with Action Model
Hello together,
I struggle with the following topic:
I created the child change request Standard Change Request (SCR) out of the parent Change Request (CR).
Now I want to have an individual order of the sections on the Details tab like Affected Objects, Attachments, Associated Process Objects, etc for the SCR. And no I don't mean the attributes layout.
I already found the current action model, which is used for all the change request types: changeRequestInfoPageTabSet
And also the section in the ChangeManagement-actionModels.xml
But when I make changes here, it will be changed for the parent Change Request and also all child objects.
I would suggest the next steps for the SCR are to create
1. a action model name="standardChangeRequestDetailsTab" for the order of the single elements
2. a action model name="standardChangeRequestInfoPageTabSet" for the different tabs
But how do I link now the new created standardChangeRequestInfoPageTabSet with the actual SCR Object? And replace the old action model with the new one?
Or how do I find out where to look?
HelesicPetr
May 29, 2024 12:44 PM UTC
Hi @NR_9463014
If you define the tabs and tables for your request, add own custom one and add an filter to that actions.
The filter helps you to show your actions(tables) only for your subtype.
PetrH
Jun 3, 2024 7:36 AM UTC
Hello PetrH,
thanks for your reply!
Could you please help me how to add it as a custom one and also the filter? Because I didn't find a solution for linking the tab with a certain (sub)type?
If you need information please let me know!
HelesicPetr
Jun 14, 2024 12:04 PM UTC
Hi @NR_9463014
in XML actionModels define the tab and what should be shown in it.
Set a filter in the actionModel for your tab and thats all.
There are also many Examples how to use the filter in a customActions..xml
https://community.ptc.com/t5/Windchill-Customization/How-to-override-ootb-validator-or-is-any-way-to-add-our-own/m-p/934297#M138%3Fsource=search
PetrH
