Customizing wgm install, specifically Autocad integration
We've gone through a re-brand on our Windchill database to fit in with the culture here at DIRTT. Everything from apache to the graphics. However there is one area that completely eludes me.  I cannot figure out how to modify the "PTC Windchill" ribbon Tab in Autocad. And possibly the "Open from Windchill" button in the open/save area.
We've explored the wgm toolkit but that seems like its for writing our own integrations. So now I'm at a point trying to figure out if trying to modify the ac2014adapter_clnt.dll file before the install is the key. However it is a dll file and is compiled already...
Has anyone had any experience with this type of modification who may be able to offer some guidance?
Hi Steve,
Can you please let me know, which Windchill version you are using at your site?
Pankaj Mooteri
Product Manager - WWGM
PTC
sknox12-AmethystAuthor
10.2 M030 CPS17
Hi Steve,
In 10.2 M030 WWGM-CPS11, we have introduced below preference. User can replace the PTC Windchill tab in AutoCAD with a customized tab which contains standard elements as per user requirement.
The PTC Windchill tab can be hidden in AutoCAD ribbon using preference “wgm.hide.menus” in wgmclient.ini file.
The values for the wgm.hide.menus preference are:
     No (Default): By default PTC Windchill tab is shown in AutoCAD ribbon menu
     Yes: The PTC Windchill tab is hidden in AutoCAD ribbon menu
Preference needs to be set in the wgmclient.ini file under the AutoCAD section.
Pankaj Mooteri
