avillanueva
23-Emerald II
October 14, 2019
Defaulting Inventory Dispositions to Blank or Null
I have done some cursory tests and cannot get the system to default to blank when Parts are added to Affected Data.  I cleared the default value and I do have an Enumerated list of values for each Inventory Disposition column.  I want to ensure there is positive indicators of a choice for Inventory Dispositions, not just accepting the defaults. Ideally, I would like blank to show up indicating that nothing was selected yet. Tried restarting server but seems to always default to first value in enumerated list though blank is a choice on the row above in drop down.  I do not have a setting that value is required in constraints.
Hi Antonio,
I see you have a Support case opened for this as well, so that's probably the best route to look into this.
Hopefully, they can figure this out, or comment on why you see this.
I wonder if SPR 9344831, has some bearing on what you see?
https://www.ptc.com/en/support/article?n=CS312932
