6-Contributor
Delivery attachments api
Hi all,
i am setting up a workflow, intended to be used for package routing that generates Part BOM xml files, creates a delivery and then attaches the xml files as delivery attachments. I have a hard time figuring out if there is a supported api that will enable attaching the generated xml files in the delivery. So far, i have only managed adding the files as package attachments.
Any ideas?
    6-Contributor
    i figured it out. For anyone interested the Windchill customization guide contains the following information:
    The IncludedContentRoles property controls which types of content files associated with a package object are added to an exported zip file (created using the “Zip for Delivery” action). Content files associated to a package by the WP_ EXP_SECONDARY content role are always added, regardless of the values given for this property.
    So using the WP_ EXP_SECONDARY content role did the trick.
    18-Opal
    Hi ​@SS_14534388,
    Which API are you using to attach the attachments?
    6-Contributor
    The AbstractWorkPackage is updated by the ContentServerHelper class (wt.content.ContentServerHelper.service.updateContent) which adds the files as secondary content.
    SS_145343886-ContributorAuthorAnswer
    6-Contributor
