Difficulties to change settings in wt.properties.xconf
- October 30, 2018
- 7 replies
- 5573 views
Hi there,
our users required to enable the search for empty attribute fields. The Windchill documentation states that this can be done by setting the property com.ptc.windchill.search.queryBuilder.enableNullCriteria in wt.properties.xconf to true.
I am used to edit settings with the xconfmanager tool. The command
xconfmanager -s com.ptc.windchill.search.queryBuilder.enableNullCriteria=true -t codebase\wt.properties.xconf -p
failed with a lengthy error message (see attached file).
In the wt.properties.xconf file, a comment has been inserted at the beginning:
#-*- XCONF CONTENT START -*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*- # WARNING: # # This file has been updated by the xconfmanager tool located in, # $(wt.home)\bin but this file is not declared by PTC as being managed # via xconf. # # To ensure that your settings will be preserved the next time the # xconfmanager is run or an installer is used to install a new product or # a maintenance update to the currently installed products: # # **** DO NOT MODIFY THE CONTENTS OF THIS FILE DIRECTLY! **** # # If you are configuring this installation and you wish to change a value # from its default, edit your site-specific xconf configuration file: # C:\ptc\Windchill_11.0\Windchill\site.xconf # using the xconfmanager tool located in $(wt.home)\bin. You may run the # command 'xconfmanager -h' to obtain a usage statement for this tool. # The following properties are specified in xconfs: # - com.ptc.windchill.search.queryBuilder.enableNullCriteria # #-*- XCONF CONTENT END -!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-!-*-
So my question is: How do I properly set options in wt.properties.xconf? And how can I revert the changes?
Thank you in advance for your comments.
Best
Chris
