Disable Authentication for endpoint
Is there a way to disable the authentication for a single endpoint (custom JSP).
hlafkirAnswer
oups sorry, the article is internal.
Here is the solution :
  1. Add this entry in the file Windchill_11.0\HTTPServer\conf\conf.d\30-app-Windchill-Auth.conf
<LocationMatch ^/+Windchill/+<directory path>/+<filename>.jsp(;.*)?>
  Satisfy Any
  Allow from all
</LocationMatch>
2. Restart Apache
Hi Alex, hope you are fine.
Did you checked this article https://www.ptc.com/en/support/article?n=CS273315 available in our kownledge base ?
Hicham
hlafkir5-Regular MemberAnswer
  Satisfy Any
  Allow from all
</LocationMatch>
2. Restart Apache
Hi
Be carful here, if you do this your jsp will not  have access to method server or databases....
Regards
