Editing a Test Case title using cmd
Hi, when I try to edit a test case using
im editissue --field=Title="My Title" idxx (where idxx is my test case id) I receive the following error
Could not save modified item idxx: MKS124079: The field "Title" is not a valid field in the Type "Test Case".
Using " im viewissue idxx " -> can see that field Title is there.
How to make it work ?
I tried updating the title manually (from gui) and it works, but still cannot use im editissue (....) and it's important for scripting.
