6-Contributor
Jun 6, 2022 6:50 AM UTC
ESI ( 902 ) : Publish request for "01001, docName, A.1" is already active.
Error:  ESI pre release : ESI ( 902 ) : Publish request for "01001, docName, A.1" is already active.
Getting this error on Method server continuously.
how to resolve this issue.
Jun 6, 2022 7:55 AM UTC
Please provide a screenshot of the error that occurs.
6-Contributor
Jun 6, 2022 8:37 AM UTC
Jun 6, 2022 8:19 AM UTC
Hi
Check that DOC is in PENDING,  PROCESSING state or not?
Looks , some Transaction is ACTIVE state..
regards
GAIN Sreeni
MarcoTosin
Jun 6, 2022 1:26 PM UTC
The most common reason for the error you reported is because there are multiple pending submissions of the object.
Normally you cannot perform a second submission of an object until the first one has been successfully completed.
If you want to check the status of the submission you can use a couple of reports that you can also find in this document.
https://www.ptc.com/it/support/article/CS58679
https://www.ptc.com/en/support/article/CS306400
Marco
6-Contributor
Jun 8, 2022 9:44 AM UTC
solved
MarcoTosin
Jun 8, 2022 9:50 AM UTC
If you share how you solved it, and what the problem was, other forum users will benefit.
Marco
