ESI response file - BOM update
We have a phantom item at the first level of the BOM that we do not want to publish as-is.
The structure is:
  • Parent → Phantom → Child parts
In Oracle, the expectation is:
  • Parent → Child parts (phantom should be flattened)
We are enabling one-level publishing only. Is it possible to generate the XML in such a way that the phantom is replaced with its child BOM (i.e., flatten the phantom during publishing)?
I’m considering two approaches:
  1. Manually manipulating the XML, though this may be complex and error-prone due to multiple scenarios.
  2. Sending the BOM for phantom instead of phantom before generating the XML.
Is there a better or recommended approach to achieve this?
18-Opal
Hi ​@Srivalli,
I am curious to understand why it is configured for one-level publishing.
