Dec 14, 2017 4:40 PM UTC
Evaluating Or Conditional Second Time Stalls Workflow
Good morning, gurus!
I have an Or conditional in a workflow.  If evaluated once to loop back through, things are triggered fine, workflow is looped back.  If the or evaluates to loop through a second time, the workflow stalls.  No errors, nothing to show what happened.  I'm assuming there is a basic something I'm missing here (I do see that the wf detects there is a multiple routing of this branch, so maybe that?
I appreciate the help.
Brian Krieger
PS:  Even if the Or condition is simply hardwired as:
try {
 System.out.println("**PR Manager **Checking for Empty Key Roles**");
 boolean continueOn = false;
 if(continueOn){
  result="SetupComplete";
 else{
  result="NotifyEmptyApr";
catch (Exception e) {
 System.out.println("**PR Manager **Unkown Exception**");
In this case, the "NotifyEmptyApr" branch would be executed.  Will execute once, but not a second time.  Hence why I figure the catch in place in the system somewhere.....
22-Sapphire I
Dec 14, 2017 5:40 PM UTC
Just need to check the box on the connector config UI to be "loop link" which turns the connector segment red
22-Sapphire I
Dec 14, 2017 4:58 PM UTC
Is your looplink red?  Likely need to reset on the loopback.
Dec 14, 2017 5:35 PM UTC
Awesome, thanks, Mike!
Ah.  Wasn't setting it as a loop link. So resetting.  Should I reset that through code? Or on the connector looping back to the task just prior to the loop back?  Or am I understanding this all wrong?  Should there be a reset path back to ground, maybe with a link back to the original task?
22-Sapphire I
22-Sapphire I
Dec 14, 2017 6:18 PM UTC
Glad that it worked.
For anyone listening... I work full time (and then some) but also do quite a bit on the side supporting WC admins on things like this (for > 10 years now). Generally get a PO for 20-50 hours, to be used as needed.  Please contact me using private message if interested.
