Jan 3, 2024 9:49 AM UTC
execute jasper report from jsp page
to execute jasper report from input jsp page I am using the following API-
 ReportHelper.manager.getThirdPartyReportExecuteUrl(reportRef,parameters);
Here, the reportRef should be of type ObjectReference and should refer to a Windchill report object. However the object that I get from the jsp page using the request.getParameter("oid") is of type WTDocument.
Now, when I try to send this object in the above API , it gives the error-
java.lang.ClassCastException: class wt.doc.WTDocument cannot be cast to class com.ptc.windchill.enterprise.report.Report (wt.doc.WTDocument and com.ptc.windchill.enterprise.report.Report are in unnamed module of loader 'app')
Kindly suggest on how to resolve this.
Ramsha
HelesicPetr
Jan 3, 2024 10:00 AM UTC
Hi @RK_10805837
You should search for the report.
How do you define the reportRef and parameters?
The WTDocument object is not report template that can be run as a report...
The ObjectReference should give you com.ptc.windchill.enterprise.report.Report
PetrH
Jul 3, 2024 6:02 AM UTC
Hi @HelesicPetr,
As the report URL doesn't support for fields & execute report method accepts only string hashmap so is there any way we can use the jrbeandatacollection source as a parameter in report?
Basically will create one list in Java with fields and then will pass that to Jrbeandatacollection so will get the data set and we can create the parameter of that data set.
HelesicPetr
Jul 3, 2024 6:40 AM UTC
Hi @@_1647
Could you provide an example?
Petrh
