Facing issue with Checkout webject InfoEngine task
Hi Team,
I am trying to checkout Part using below taks I have created
<%@page language="java"%>
<%@taglib uri="http://www.ptc.com/infoengine/taglib/core" prefix="ie"%>
<ie:webject name="Get-Properties" type="MGT">
 <ie:param name="ATTRIBUTE" data="wt.federation.ie.VMName"/>
 <ie:param name="GROUP_OUT" data="properties"/>
</ie:webject>
<ie:webject name="Query-Objects" type="OBJ">
 <ie:param name="INSTANCE" data="$(properties[0]wt.federation.ie.VMName[0])" />
 <ie:param name="ATTRIBUTE" data="name"/>
 <ie:param name="ATTRIBUTE" data="number"/>
 <ie:param name="GROUP_OUT" data="parts"/>
 <ie:param name="TYPE" data="$(@FORM[]typeOfObj1[])"/>
 <ie:param name="WHERE" data="number='$(@FORM[]number1[])'"/>
</ie:webject>
 <ie:param name="GROUP_OUT" data="document"/>
 <ie:param name="TYPE" data="$(@FORM[]typeOfObj2[])"/>
 <ie:param name="WHERE" data="number='$(@FORM[]number2[])'"/>
</ie:webject>
<ie:webject name="CheckOut-Objects" type="ACT">
 <ie:param name="GROUP_OUT" data="checkedOutParts"/>
 <ie:param name="OBJECT_REF" data="$(parts[]obid[]) "/>
 <ie:param name="TYPE" data="wt.part.WTPart"/>
</ie:webject>
When Query object blocks are working I am able to fetch part and document, as I add Checkout part webject it throws below error can you please help
<?xml version="1.0" encoding="UTF-8"?>
<wc:COLLECTION xmlns:wc="http://www.ptc.com/infoengine/1.0">
<Exception NAME="Exception" TYPE="Exception" STATUS="-1">
<wc:MESSAGE>wt.ufid.UfidException: Malformed Windchill Remote Object Identifier
Nested exception is: java.lang.ClassNotFoundException: VR
Nested exception is: wt.ufid.UfidException: Malformed Windchill Remote Object Identifier
Nested exception is: java.lang.ClassNotFoundException: VR; nested exception is: wt.ufid.UfidException: wt.ufid.UfidException: Malformed Windchill Remote Object Identifier
Nested exception is: java.lang.ClassNotFoundException: VR</wc:MESSAGE>
 <wc:INSTANCE>
 <hierarchy>com.infoengine.util.IEException</hierarchy>
 <hierarchy>javax.servlet.jsp.JspException</hierarchy>
 <hierarchy>java.lang.Exception</hierarchy>
 <hierarchy>java.lang.Throwable</hierarchy>
 <hierarchy>java.lang.Object</hierarchy>
 </wc:INSTANCE>
</Exception>
</wc:COLLECTION>
Hi SM_10840693,
The parsing of the info*engine seems to be wrong as it s interpreting the version reference of the part as the object class. The resulting class should be wt.part.WTPart.
Community Moderator
Hi @SM_10840693,
Anurag
I don't know if you have gotten past your issue posted here yet, but the reason you are getting this error is that there is more than one result in your group "parts", therefore $(parts[]obid[]) does not apply for checkout, for you can only use this notation successfully is when there is only one item in your group.
I would estimate that you need to first provide proper searching to only give you the one you are interested in, or sort (not included in my reply) the data accordingly and only use the first one in the group with the syntax of $(parts[]obid[0]).
If you are interested in the latest part, then a sort for that can be done, if you allow check-out of non-latest or older revisions, you will need to provide a way to get to the correct part iteration.
